ATI 8500 cooling!
CyberFed
My roomate is buying a Radeon 8500Le and he's too lazy to ask the question so i'll do it for him.
Does anyone know of fans that can be put on the chip to cool it better than the stock cooling, i know there are the blueorbs for geforce cards, but will these work w/ATI if not does anyone know of any that will thanks in advance
NASsoccer
On a string I was held Senior
i live
you can use a blord on the ATi or a crystal orb and any IU cooler. The only difference is the ATI doesn't have the mounting holes, so get some artic alumina epoxy and still it on.
Silversinksam
Moderator/ Silver Paste Taster©
Sunshine State, USA
An IU cooler will not fit without slight modification to the top left corner..
I know this because i had an Alpha pal 15u on mine (60mm x 60mm x 25mm)
A Crystal Orb fits nicely but you'll need some Adhesive like NASsoccer recommended:rolleyes:
