Here is a comparison between the current Catalyst drivers including the Catalyst Control Panel and the Omega 2612 driver, running benchmarks under 3DMark05:
The test were run on a fresh install of Windows XP Pro, the computer specs were the following:
Asus P5AD2-E Premium
1GB OCZ 5400
WD7400 2-drive Raid 0
Intel P4 660
ATI Radeon X850 XT PE
Everything on the computer was set to stock speeds ( 540mhz core / 587mhz memory) - all The Catalyst driver 3D options were set to max performance.
I ran each driver 3DMark05 benchmark 3 times ( installed driver 5.4 - uninstalled driver - installed next driver....started 2nd round of benchmarks...3rd round)
The below benchmarks are the average of all three runs:
Catalyst 5.4: Average Score: 6270
http://service.futuremark.com/compare?3dm05=787212
Catalyst 5.3: Average score: 6288
http://service.futuremark.com/compare?3dm05=787233
Catalyst 5.2: Average score: 6285
http://service.futuremark.com/compare?3dm05=787125
Catalyst 5.1: Average score: 6222
http://service.futuremark.com/compare?3dm05=787146
Catalyst 4.12: Average score: 6028
http://service.futuremark.com/compare?3dm05=787580
Omega Driver 2.6.12: Average Score: 6146
http://service.futuremark.com/compare?3dm05=787178
TechPowerUp 5.3 based driver: 6277
http://service.futuremark.com/compare?3dm05=787717
ATI Cat 5.3 without Control Center: 6276
http://service.futuremark.com/compare?3dm05=787825
I have to add that I am not familiar with the Omega driver and have not seen any performance settings off hand to match the optimized for performance settings I used in the Catalyst control panel.
Overall I can attest that for pure 3DMark05 benching purposes the Cat 5.3 with Control Center is the best pick.
Cheers
Mike
PS let me know if you want me to bench any other drivers in this comparison.
EDIT: I just added the Techpowerup Driver results ( ran it twice) as well as the 4.12 ( only ran it once since it's too far off) - Ran the Cat 5.3 to see if any changes happened and got again 6288 after running the other drives ( http://service.futuremark.com/compare?3dm05=787744 see the timestamp )
Edit: A big surprise to me was that the Catalyst without the Control center was actually a tiny bit slower - by about 10 points - the same with Techpowerups version of this driver. I assumed that this one would be faster, having less overhead. I had all settings also set to max performance.
1GB OCZ 5400
Intel P4 660
Cheers
Mike
