- Jan 11, 2011
- IT'S COLD HERE
Here is the Instructions I got from skildude over at the seti message boards.
1. Download the appropriate OpenCL version of ati drivers
2. uninstall your old ATI drivers.
3. Install new ATI drivers, current version 11.1 you'll need to restart your computer
4. download the multibeam apps from Lunatics. At this point stop running BOINC. Make sure all the BOINC processes are turned off in the task manager (CTRL-Shift-ESC)
5a. for Windows vista/7
unzip then copy/paste the lunatics ati multibeam app into your c: /program data(may be hidden ask for info how to unhide)/BOINC/projects/setiathome.berkeley.edu folder.
5b.for windows 2k/xp
unzip then copy/paste the files into the C:/Documents and settings/(user folder-mine is under "all users")/Application Data(may be a hidden file)/BOINC/projects/setiathome.berkeley.edu folder
6. have an app_info file yet?
7a yes. continue to 7b No. skip to #8
7b. for 4XXX series ATI cards, locate your app_info in the same folder that you just put the ati files.
paste this app_info data into your current app_info between the second to the last and last line </app_info>
<app>
<name>setiathome_enhanced</name>
</app>
<file_info>
<name>MB_6.10_win_SSE3_ATI_r177.exe</name>
<executable/>
</file_info>
<file_info>
<name>MultiBeam_Kernels.cl</name>
<executable/>
</file_info>
<app_version>
<app_name>setiathome_enhanced</app_name>
<version_num>610</version_num>
<platform>windows_intelx86</platform>
<avg_ncpus>0.05</avg_ncpus>
<max_ncpus>0.05</max_ncpus>
<plan_class>ati13ati</plan_class>
<cmdline>-period_iterations_num 2 -instances_per_device 1</cmdline>
<flops>20987654321</flops>
<file_ref>
<file_name>MB_6.10_win_SSE3_ATI_r177.exe</file_name>
<main_program/>
</file_ref>
<file_ref>
<file_name>MultiBeam_Kernels.cl</file_name>
<copy_file/>
</file_ref>
<coproc>
<type>ATI</type>
<count>1</count>
</coproc>
</app_version>
7c
for 5XXX series cards install this app_info
<app>
</app>
<file_info>
<name>MB_6.10_win_SSE3_ATI_HD5_r177.exe</name>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
<app_version>
<cmdline>-period_iterations_num 2 -instances_per_device 2</cmdline>
<file_ref>
<file_name>MB_6.10_win_SSE3_ATI_HD5_r177.exe</file_name>
<main_program/>
</file_ref>
<file_ref>
<copy_file/>
</file_ref>
<coproc>
<type>ATI</type>
<count>0.5</count>
</coproc>
</app_version>
This is from my app_info. if you don't want to or are unable to run more than 1 WU at a time please remove -period_iterations_num 2 -instances_per_device 2 from your command line.
8. Say what no app_info. The easiest way to get one is to install optimized apps. found here. install either the 32 bit or 64 bit which ever system you have. you'll need to know which level SSE, SSE2, SSE3, SSE3(amd), SSSE3, or SSE4.1 you can run. once you have the optimized apps installed and you can return to 7b.
close the app_info, close other folders. restart BOINC. you should be able to start downloading 6.10 multibeam wu's they should start processing from there
<app>
</app>
<file_info>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
<app_version>
<file_ref>
<main_program/>
</file_ref>
<file_ref>
<copy_file/>
</file_ref>
<coproc>
<type>ATI</type>
<count>1</count>
</coproc>
</app_version>
7c
<app>
</app>
<file_info>
<executable/>
</file_info>
<file_info>
<executable/>
</file_info>
<app_version>
<file_ref>
<main_program/>
</file_ref>
<file_ref>
<copy_file/>
</file_ref>
<coproc>
<type>ATI</type>
<count>0.5</count>
</coproc>
</app_version>
