Ati ( original ) Radeon 9600 problem
Problem
Hello!
I get original Ati Radeon 9600 128 mb ddr divi bla bla bla ... graphic card for present. But I have problem. When I put my card in computer and start up there is no picture on screen. Fan on graphic card is spining , and power on button on monitor is yelow ( it shoud become green ...)
MBO - IC7 abit
what is the problem ?
:confused:
P
Problem
There ar no bips from PC speaker , and card is pluged all the vej in .
System is normali going up , onli there is no picture on screen.
Can it be that vga conector on graphic card is not functional ?
Should I tray conect over DVI adapter to DVI conector on graphic card ?
The Coolest
Senior Member
Also, this might be a longshot, but do you have a PCI card installed in the computer as well? or maybe onboard graphics?
If you have a PCI card, connect the monitor to it, boot up, you'll have a picture. Go into the BIOS and change the primary display to "AGP" so now the computer will start up using the AGP card. If you have onboard graphics, connect the monitor to it, boot into the BIOS and just disable it in the BIOS.
