I'm folding gromacs with lots of linux box and sometimes it is real hard to maintain b/c servers on gromacs always run out of work units and make my box wait for ever getting work. Go into each box and restart the fold job without the gromacs options is time consuming. So I've written a scripts to automaticly switch to tinker cores when there is problem. Also, there is a bug in linux folding program where it will not go under 6% of cpu usage when I'm using the computer. Thus, if you fold you can not use full speed of your box when you need the cpu. Therefore, I wrote a perl program to handle all of the above issues for my own use and also want to share with others users that have the same frustration like I do.
Read the top part of the program for how to use the program. Minimum system requirements is. Linux with perl,awk, grep and egrep installed. I tested it with redhat and gentoo and it works just fine.
If someone wants it you can download it here for single cpu box.
http://home.swbell.net/trangpho/fold
EDIT: new file fix some bugs I found today. If you have a dual processor box you can uncommend the lines as noted in the program.
