audigy 2 plat to zs series upgrade
Airbornederekc
Massachusetts
ok heres my question i have an audigy 2 platinum with the i/o drive
i think i killed the card so if i upgrade tot he audigy 2 zs gamer card can i just hook the i/o drive up to the newer card or is there an incompatibility issue?
micamica1217
should work, yet check newegg's pics to make sure they didn't change the connections.
you will need to update to newer drivers, that's for sure.
mica
Airbornederekc
Airbornederekc
Massachusetts
umm just jot off the phone with creative and they said that the drive will not work. the drive is card specific. aint that a bunch of bull now i gotta go spend 200 bucks on a new card
JCLW
Can you post a high res picture of your Audigy 2 card? In particular the pins where the live drive plugs in?
Ad Rock
Montréal, PQ, Canada.
This is just the distrusting consumer in me but I dounbt that the drive is card specific. Unless they changed the connector which I doubt I dont see why it wouldnt still work. It would be really expensive to make serperate external drives for each card when they didnt change them. Then again I could be totally wrong.
JCLW
They changed it between the Audigy 1 and Audigy 2, to stop third party manufacturers from making cheaper add-on stuff :( I'm not sure if the A2 is different then the A2 ZS. Somehow I doubt it, but if I could see the pinout I might be able to tell.
