Audio Control
Hardass
Senior Member
I deleted the on board audio by mistake. I have reinstalled the drivers but still don,t have volume control back have tried everything, any ideas
AntiHeiss
Senior Member
Texas
Are you sure you installed the correct driver? Try that. A buddy of mine had the same problem and it turns out that he tried to install the wrong drivers. Also, it may just be worth a look to check your BIOS and make sure that the onboard audio isn't disabled.
Good luck.
