audio popping/static help!
Agent Z
Helena, MT
Ok here is the deal....i recently(2nights ago) somehow shorted out my powersupply....well my sound card does this staticy popping noise whenever i play Delta Force Landwarrior....now my audio is fine whenever i do anything else even in the menus of the game it is fine...and i have tried updateing windows and looking for a new and updated driver...i have tried dif speakers also and i get the same results...static popping...errg
lazerin
Australia
This probably won't help...but try cleaning the connections. Bad connections (eg dust etc) are usually the most common cause of static noise in audio.
Agent Z
Agent Z
Helena, MT
heh didn't help...i am going to try and install a dif sound card to see if that helps
