Auto regolation pump's speed with cpu and gpu cooled
Merecol
Hi guys.If I have a pump with pwm regolation but I am cooling cpu and gpu, the regolation of pump''s speed in base of what is regolated?Cpu's temperature or gpu's temperatures?
Lochekey
Senior Pink Member
That will depend. What do you have the pump hooked into. I assume it is hooked into a motherboard header. If this is the case and you did not fiddle with the fan profiles then it will be driven by the cpu temperature.
