- Jan 31, 2003
- San Francisco, CA
Re: You Guys are great!
i have overclocked ~10 tualatins (6 celerons and 4 p3's) and 2 celerons hit 1.6 and the 4 others hit only 1.55 (but all required 1.63 volts or more)...
i think that getting a 1.2 is worth the risk to hit 133...but only if you do voltage modification....you will almost for sure need more volts...
as long as you can sell the 1.2 or trade for a 1.1 then get the 1.2 first and if it doesn't work go for the 1.1
you might be able to place a wanted add and look in the classifieds for a 1.2 that does 1.6 ghz that someone will sell you...
definitely don't get the p3 unless you need the extra cache for programs like seti....or unless you want to run a dual processor...
I love all this advice!
The limiting factor on overclocking the Tualerons is the Intel D815EEA's fixed buss speeds of 100 or 133Mhz Front Side Buss. Thus, overclocking the Cel-T is a 33% (by insulating the BSEL pin) or stock proposition.
If I got the the 1.2 Cel-T to run at 133 FSB, the 12% Mhz advantage over a 1.4G PIII-s should balance out the approximately 10% speed advantage the the PIII-s has over a Cel-T of the same speed. The 133 Mhz FSB is important to me because I can't run the memory asynchronisly, and the PIII's memory bottleneck is the second disadvantage it has over the the P4. The first, of course, being the absolute megahertz limit.
I see on the Database that only 1 1.2G Cel-T with a S-code of SL68P or later didn't make 133 FSB, and 4 actually made it with stock voltage! I also notice that those are all Phillipine chips. I suppose with the prices as low as they are, I could gamble, and then order a 1.1Ghz Cel-T if it doesn't work. All of the 1.1Ghz Cel-Ts made 133 FSB (at least), but only 2 people ran stock voltage.
