- Nov 13, 2001
- Ioannina, Greece
Has anyone tried this combination? The A7V266 has two capacitors right beside the top-left corner of the cpu socket and I think the AX-7 won't fit. The GlobalWin WBK which is a bit smaller in length than the AX-7 (75mm as opposed to 77mm) seems to me like a tight fit.
Summer is approaching here in Greece and high ambient temperatures (35C-40C) are the norm, while in the VERY hot days it can go to 44-45! The WBK doesn't cut it, that's for sure, so I was thinking of getting a better heatsink. A big air-conditioning system would be nice too, of cource
So, if anyone has had success in fitting the AX-7 on the A7V266, please tell me. Now that I think of it, could I trim that corner a bit so that the hs will fit? Or is the fan screw in the way?
1. "GameBoy HIGHLY advanced"
Case highly modded ([email protected] and [email protected] Sunons for intake, [email protected] and [email protected] Sunons plus the p/s fan for exhaust, GlobalWin WBK heatsink with Sunon [email protected] using a spare fan grill)
Athlon TBird 1.4 (Stock speed due to heat problems
Asus A7V266
256MB DDR Kingston
Gainward GeForce3 Ti550
2 x 20GB HDs (WD & Seagate)
DVD Hitachi 2500
CDRW Plextor 2410A
WinME
2. "Penguin"
PIII 550 / 256MB RAM / 20GB Seagate & 6.4GB Quantum HDs
QDI Brilliant 1S
Creative GeForce2MX 32MB DDR
Mandrake Linux 8.1
Asus A7V266
256MB DDR Kingston
DVD Hitachi 2500
CDRW Plextor 2410A
WinME
2. "Penguin"
QDI Brilliant 1S
Mandrake Linux 8.1
