I'm thinking of getting the Thermalright AX-7. I already have a Delta 4000rpm/46.1cfm fan. (40dba) Good combo or not? The fan should fit just fine shouldn't it? Thanks, Kent
sadly not, the fan you are suggesting is a 60mm model, the AX-7 is a huge heatsink which is designed to take a 80mm model, for best results a 69CFM delta should be used, (or even better the 80CFM one if you can find it)
