What fan would yall suggest for an AX-7? Noise is very important, but I would like some decent overclocking potential (even though those dont go so well together ). Is there a brand that tends to run quieter at higher speeds?
Here is an idea, the AX-7 uses a 80mm fan right? Go to this website: http://www.plycon.com/ and check out the 80mm to 120mm fan adapters. I would then pair this with a Sunon KD1212PTB3 fan from : http://www.crazypc.com/products/fans/fans.htm#120x25mm .
This fan puts out 69cfm which is more than the Delta that was put on it for the test here and only puts out 35dBA! This fan is very quite (I know because I can sleep with it, 1 80mm, 1 60mm, 1 P/S 80mm and the 60 on my hs) and my whole system right now is probably only around 40dBA. You said that noise was an issue, so their you go. I hope this helps.
