tried unlocking and accidently filled the cuts with a conductive glue(i think thats what happened?) cant set ANY multiplier.. set lower then 10.5x and cant post.. higher and it reverts to 10.5x.. even after cleaning with finger nail polish..
i've cleaned it over and over .. i dont think i can fix it this way.. im assuming if i try to reconnect the bridges it wont work since as of now it wont post at lower multipliers..
its a green aroia y 13 .. has the short gaps..
just wondering if there is any other way I can unlock? or set a custom multiplier somehow by cutting/connecting other bridges since i've messed up L1s..
my cpu is doing 166*10.5 right now.. not so bad, but I'd like to run at a higher FSB..
thanks alot
thanks alot
