AZUS A7V133 board
Harry
CA. USA
I am thinking of buying this board what do you think has 266fsb have a 900TB to use for cpu.
Thanks guys for comments
It will work with a TB900, but it might not work at 133. Your TB900 is a B-which is made to run at 100, so even with the board capable of supporting 133, you may not be able to run your cpu at that speed. I do have a 1.2"b"(axia) that runs at 133 without a problem. You could always get the board and use it with your cpu for now, and upgrade to another cpu "c" later.
I've got a 1.2G "C" T-BIRD @ 1470 (10.5*140) on my A7V133. The board supports up to 12.5*, as do most of the others, it also officially supports 133 FSB but will go much higher depending on other components such as RAM, video card, NIC etc. Some have reported FSB's in excess of 150MHz on this board.
