Bacitracin Zinc Ointment works as Thermal Compound?
a c i d.f l y
Austin, TX, USA
Heh, it is a first aid antibiotic, and it worked relatively well. Dropped CPU idle temps by four degrees. 38°C to 34°C. Works better than nothing, I guess?
Ingredients:
500 units Bacitracin Zinc per gram in white petrolatum base.
-Store at room temperature 15°C-25°C.
...wonder what problems await? *laughs*
-Frank
Mico
Marrietta, GA
I put something that cools better than as3 in my mouth? Maybe it's all the 'cool' mint flavoring that drops the temps. (Haha! Look at my joke! I am such a funny person...heh...yeah, I'll shut up now).
a c i d.f l y
a c i d.f l y
Austin, TX, USA
....well, I didn't have anything there before, and I know it'll dry up, but it'll still transfer heat then. It is still running after about two weeks.
-Frank
rogerdugans
Linux challenged Senior, not that it stops me...
Corner of No and Where
lol!
I love creative thinking ;)
Keep us updated as to how it performs long term, will you?
I'm very curious about the longevity and performance loss.
RoadWarrior
Senior Member
Niagara Falls, Ontario, Canada
I did a test once with "nappy rash cream" Which is zinc oxide in a castor oil base. It was a bit empirical but here's what I found.
I didn't have much in the way of sophisticated measuring equipment, so what I did was got some aluminum bottle caps and a small cup sized hot plate. I put a small amount of water in the bottle caps and timed how long they took to boil.
The cap that was "dry" took around 2 minutes to boil.
The cap that had zinc oxide cream under it, took around 1 minute to boil.
The cap that had generic zinc oxide heatsink compound under it took around 30 secs to boil.
I noticed that there was a lot of stuff boiling out from under the cap with the zinc oxide cream, I think there was some alcohol and other lighter things in it. So I put a capful of the stuff on the hotplate and left it overnight, until it was thicker and more the same consistancy of the zinc oxide heatsink compound. Then, testing a cap with this under it showed the water boiled in 40 secs.
So I concluded that zinc oxide cream is not quite as good as generic thermal compound, but it seems significantly better than a "dry" interface.
Also I think that were a heatsink installed long enough for both zinc oxide compound and the zinc cream to completely dry out, then they would be about the same.
regards,
Road Warrior
a c i d.f l y
a c i d.f l y
Austin, TX, USA
Yeah, which was my theory. The petrol substance would dry out, and I'd still be left with a film of zinc in the microscopic pores, thus making for a better transferable substance... I'll check it when I get it plugged back in at home.
-Frank
