Is there software that will make a list of all the directories>files on a HDD?
Borisw37 Member Joined Aug 19, 2003 Dec 17, 2005 #1 Is there software that will make a list of all the directories>files on a HDD?
Bios24 Member Joined May 29, 2004 Location Kansas City, MO Dec 17, 2005 #2 Just make a list? or back-up everything? FYI- I use Cobian back-up for my rig. It's free and has lots of options.
OP Borisw37 Member Joined Aug 19, 2003 Dec 17, 2005 Thread Starter #3 Yep, just make a list. My HDD is dying, I NEED to know which files are on there, so I can back-up the important ones 1'st.
A anon1 Member Joined Jun 8, 2005 Dec 20, 2005 #4 If you are using Windows, use this link: http://www.theeldergeek.com/file_list_generator.htm If you are using Linux or UNIX, go into your directory, and type: ls -R
