Backplate Removal for A8V
Goldstandard
California
I got a new thermalright slk 948 and I cannot get the backplate off, I am afraid of breaking the motherboard. Do any of you know how to get it off?
squirtle632
Next Door door to Hell
You might now want to hear this but you can put it into a freezer INSIDE a ziplock bag for about 15 minutes. That should freeze the glue and make it easier to remove.
I accept no responsibility for things that go wrong. Just repeating what I have read elsewhere.
G
Goldstandard
California
Thanks for the tip, but I found my own solution
I finally figured out reading some other posts that I could heat the backplate to soften the glue and then pry it off with a plastic card. When done carefully it is quite easy. Just don't try and heat it and pry the plate at the same time, you will melt the plastic card, as I almost did.
My new heatsink works quite well. :D
