Bad overclock
boX_BR
hi
im currently running on this specs:
abit nf7-s rev2.0 beta bios 1.4 ( didnt like the retail one)
2100+ AXDA2100DUT3C AIUHB0302TPCW
512 kingston hyper-x 2700 @ 215 (stable)
volcano 11
temperatures running @ 2000 mhz - 35 idle, 42 full
my problem is that I cant go past the 2100 mhz.. I already set the vcore to 1.85, but it still wont get stable... currently im burning in at 9.5 x 215, vcore 1.8 (lowered it down cause i got a siren sometimes when higher) and vdimm 2.8 (gets to 2.9, abit overvolts it).
if I set the vcore higher it wont post, and starts that siren, but the temperatures arent that high... and I can't get higher mhz.... already tried lowering to 166 and 200 fsb, but no way. :/
is that just a bad chip or is there something i could do to make it improve?
woods
Fort Worth Texas
sounds like the chip cant handle the fsb. I dont know why it wouldn't but it sounds like it. 1.8v should be good up to 2300 or higher. could be your mem timings. maybe a little of the magic smoke got out.:D
B
boX_BR
so its a PSU problem? my voltages seem ok...
the only one who seems to change too much is the -12 and the -5... is that a problem?
Milkman
NH Biodiesel master
I found my Aiuhb 2100+ 0302 liked higher multi's and lower Fsb much better, I ran at 166x14 for a long time at 1.8 volts max and it was very stable.
B
boX_BR
JetMech said:
2700 memory at 200+fsb? what is the memory voltage?
ill try that.. btw
its Kingston Hyper-X 2700
running @ 6-3-3-2.5 @ 2.8 vdimm (shows 2.9 on mbm)
B
boX_BR
lol i just tried 133 x 17, it posted on windows but failed on prime... I guess i got a bad chip :/
B
boX_BR
why do I get this siren when i try higher clocks? that sucks, my temps arent bad... 45 full load isnt bad
Audioaficionado
Sparkomatic Moderator
That newer 1.4 BIOS doesn't work well with all multipliers. I lost 'em all below 11. Maybe you could try the 1.2 again and just subtract 10c off your core temps.
B
boX_BR
you mean it doesnt get stable with all multipliers? wich ones are not correct? cause I dont fell well when seeing 50+ temperatures :/
Audioaficionado
Not for my setup. <see sig & profile>
I lost one of my favorites 200/2000. Stable at 1.5v and ran FAH WUs like crazy.
Others have been having problems too.
Search the Abit AMD mobo section for the threads.
B
boX_BR
hmm currently running at 215x10.5 ( 1.85 vcore)... it seems stable... I think burn in really works *woot* :)
B
boX_BR
1.4 ;) I dont like that high temperatures
jonspd
Super Speedy Senior
This may or maynot have been asked what si your vdd @ and also what are you temp's when running prime @ it's highiest stable overclock.
Keep in mind a volocano 11 isn't the best for a hsf when it come's to overclocking your cpu.
B
boX_BR
I live in brazil and it's very hard to get a better heatsink.
Temps at prime are @ 45... vdd 1.7
