- Feb 25, 2004
- N of splat W of Torin
Good news Bad news tonight. New PC #5 in sig . Lit up seemed fine in every aspect other than a boot screen. Pulled GPU. Then pulled the RAM module and left a single in the correct slot. That was the problem, Booted up and I installed Windows 11.
Tomorrow I'll swap the one in there with the one I pulled and suspect is Bad. So if it works I wonder is that indicates the slot is bad. Probably the first time in 10 years I did not get G skil. I went with Lexar. I'll have no trouble returning them to Amazon if needed. I can take a couple out of another PC to use till I get another set.
Just glad I stumbled upon the issue so quickly.
As a side not I used an XML script for the first time on a Windows 11 install and it went perfect. Did the whole install without having to answer any questions. Also kept most all bloat ware off.
