- Nov 16, 2001
I have just swapped out my old Neo2 for the NF4 Infinity SLI. I am using the same cpu (3200+), hsf (XP-90/Delta), ram (PC4200 Hyperam 2x512), psu (Fortron BlueStorm 500w), case, etc. Everthing the same except the DFI and a 7800GT. I could get 2.6ghz @ 1.525 with the MSI. Most I have got stable with the DFI is 2.3 @ 1.525.
Over that and I start getting problems that remond me of having the PCI bus too high, back before the busses were locked at 33/66. Weird things like failing to load Windows properly or all the way. Little hags and hesitations. Just some weirdness I never got before the DFI. So I have some questions
1. The busses are locked on the DFI, aren't they?
2. Does it matter which SATA port you use? It did matter on my Neo2, 2 were locked and the other 2 were not.
3. Do any here load the Nvidia SW-IDE driver? It is recommended not to over at DFI-Street, so I have not.
4. Are all DFI boards this tempremental?
When I decided to start on an SLI upgrade path I first checked the MSI threads for what was thought of the Neo4-SLI. It seemed from the posts here that the quality had slipped some since my last board so I started looking at other options. That led me to the DFI and now I am beginning to think I may have made a mistake. I have a new Opty 165 and a 2 gig kit of Gskill Extreem coming for this. I hope it will help or at least work better.
