- Jan 5, 2023
I heard about that online, and then when I met him and saw the dialogue options I thought "uh oh".
So I've noticed health points have been fluctating. This was taken just now. My main character's an assassin/rogue. Why do the rogue, cleric, and warlock all have higher HP than the barbarian at the same level?
This is post-patch, BTW.
Like I'm going into this with just a general broad understanding of RPGs. I was using the assassin as the glass cannon, the one hit killer. The cleric as the healer. The Warlock as a general spellcaster. And the barbarian as the tank. Like WTF?
The only problem is that you can use a sneak attack almost only once per fight and sometimes not even once, as some groups see you before you can come really close. Compare it to regular mage attacks, range and aoe, or druid/owlbear jump+2x high damage attack just after that, or barbarian/fighter high damage multi-attacks without any sneaking. No matter how you compare that, rogue looks pretty weak or requires more (often unnecessary) work for the same result.Rogues are powerful in BG3...you have to augment with the Illithid Powers:
- Favorable Blessings: bonus to first attack roll
- Luck of the Far Realms: when you make a successful attack roll, you can change that to a critical hit
This allows for Astarion to "almost always" land a critical hit on a sneak attack on his first attack of a fight...he will usually hit for 40+ on his first sneak attack.
Could be worse, the gay bear could've found you by now
Baldur’s Gate 3 has a gay bear love scene and people are loving it
The reveal of a rather unorthodox romantic encounter in Baldur’s Gate 3 has given its sales a considerable bump on Steam.metro.co.uk
"The scene in question involves Astarion, who is an elf vampire, and Halsin, who is a druid. If you manage to encourage them into a romantic relationship then a sex scene can result which involves Halsin turning into a bear – like Beorn from The Hobbit.
Although there are jokes in it – the bit with the squirrel is great – the scene isn’t played for laughs and is actually more romantic and adult than almost any other sex scene in gaming, not that there are many.
The explanation is that Halsin’s transformation is accidental, as he gets carried away, but Astarion is into it and they both carry on regardless. Or at least he is depending on which dialogue options you choose."
Well, you can try lowering graphic settings 1st? Anti-aliasing especially that you shouldn't need at 4k, shadows, SAO, stuff like that. If that's not good enough, maybe lower to 1440p? Or, well, if that's just an excuse to grab a new GPU, then hell yeah, go 3 fan
Should depend on brand/fan quality, my PNY was horrible so I modded it (sounded like a bloody jet engine at anything over 60%), I remember hearing the ventus were loud as well, but my father says he's gigabyte and Asus are fairly quiet - although keep in mind that some cards have oversized coolers that look like they were designed for higher models, so... Yeah...Yeah but are those things quiet? Remember I already tried going all the way down to 1080p... Made absolutely no difference at all. (So I've gotta jack the graphics back up to 4K next time I play.
If you take a look at performance reviews, you'll see that even with a modern flagship-class processor, FPS barely move up at all from 2560x1440 to 1080p, even with settings on ultra.Remember I already tried going all the way down to 1080p... Made absolutely no difference at all.
I like Woomack's suggestion to limit the fps via vysnc and or lowering power limits on the gpu to see if that helps your noise situation. You'll likely have to use a combination of suggestions as a 2060 Super at 4k isn't a 60 fps card (default ultra settings).... a 2080ti isnt. So I can see why the GPU is pegged (normal and good in most cases, lol) with the fan cranked which makes me concerned that limiting power or enabling vsync may really cut fps. Gotta try and report back.
3 fans can be (always??? No) more quiet than one or a blower (no idea which specific model asus you have) situation. Depends.
Well, yeah... but a midrange card from 2.5 generations (4+ years) ago can be long in the tooth on some titles.Yeah but I would've thought I should be able to run at 1080p without the damned thing going supernova...
I can't remember... but I thought I even tried 1080p with settings on "High"...
I'll try that now and then try with V-sync.
Honestly I'd be happy with 30fps. I'm really not the type that could tell the difference between 30 and 60fps on a 3D app anyway... (I could if it was a video shot on a Sony A7SIII!)
