- Sep 7, 2013
Happy birthday!
I like that blower vent idea, just pipe it out a window!
Happy birthday!
i think the cooling solution is being overthought you will most likely be fine if the server case flow is from front to back. front being the side facing you. that way they will always be pulling in cool air from the room. unless the under stairs is sealed in completely even that shouldnt matter.
looks cool though good luck with the build.
biggest thing being in the basement if you dont have a dehumidifier might look into one for down there.
That duct blower will be LOUD! I've not worked with one but I've seen them on several shows (about construction) and they are the root of all that is evil.
I agree that you are overthinking the cooling solution. Also, for CAT-5/6, you don't need conduit. Unless you have a specific reason for it, skip it.
Pure awesomeness!
Awesome!!
Wonder how you got all that wood ...
really cool man. sub'd
"Fell" off a truck?
Great score Dalchi!
Ahhhh so THAT'S where it's from!!!
