- Dec 25, 2004
I've got a legacy type problem. We switched from using an on-site system to using a managed server for our EDI communication at work. Seems to be working fine in general, except for a filename issue.
We used to get our 830 files named in this format Rxxxxxxx. with the x being hex numbers. Our Access program that updates our databases is set up to use this naming format, and I don't have the skills yet to change it.
The 830 files we are getting from the managed server look like this: 830_ib.EDI_20160924_231249_1442392
I can manually rename the files in about 15 to 20 minutes once a week. But I'd like to automate the process. Can anybody point me to a guide that would let me write a batch/cmd file that would take all 830_ib.x files and rename them in the Rxxxxxxx. style? The exact numbering isn't critical, they just need to not have duplicates and be 0123456789ABCDEF characters, other than the initial R.
Thanks!
Thanks!
