Bay Bus help
Kulchenko
Someone can tell me one links to a home made baybus?
And if someone understand about resistors what resistor should i use to pass 220v to a 2v led?
mcrites
Herndon, VA
Are you passing 220V straight to the LED, or is the psu toning it down to 12V? That'd be a lot of resistance for 220V :)
K
Kulchenko
My fan is 220v volts not 12v... thats the problem. I don´t know what resistor to use
mcrites
Herndon, VA
I just want to make sure, but are you powering it with 220 volts? But anyways the formula for resistance on the led is
(source voltage - forward voltage) / amps to run led
so
(220 - 2 ) / .02 (common amp for leds) = 10900
Correct me anyone if I am wrong :D
