BE6-II REV 1
Just shoot
Dairyland
Shuts down when under load. Can't get into bios long enough to look at anything. Will boot but then quits. Anyone have any suggestions or has had the swame problem?
Is this a new install or did it just die on you? What video card? Have you tried disconnecting everything except the video card? Need more info on system and when prob started and what you've done to troubleshoot it so far
Pulled motherboard out and replaced p3v4x and problem went away. Since have went to abit sh6, basically the same as sa6r except slot one and no raid (very nice). Everything else remand the same the system was stable for over four months.
PIII 850 @ 1003 water cooled
128 mb pc 150 cas 2-2-2
western digital 18 G ata66
Voodoo 5 5500 at 182 clock
nic everywhere network card
16x acer dvd
Re-set Cmos, just install ram and vid card and run mobo out of case on table and see what happens. Try ram in second slot.
