be6ll r2
M
madmax
Guest
getting a new motherboard tomorrow is the any thing i should know about this board before I install it . I have been reading the forum and it look like that raid part is very difficult to installed.i have a bxr6r2 now and it was easy to install , any tips will be appreciated thank you
i just got that board to and the only problem i have had is with my ram. you have to make sure that the sticks are seated properly and tight (it is easiest to do it when the board is out). i have had not probs with raid. just hook up you hdd to the raid cable and go.
