well
im going to write this up (my notes on the system)
firstof all, it took nearly 2 weeks for my package to arrive.... very disturbing
the aquacoil is verylarge, and very hard to mount but does have great cooling performance, the coil get very cold with the 120mm fan blowing air accross it
the pump is a little weak, but i am running my system in my case, so it doesnt pump far
the cold block seems to be very good, but! the new socket clip SUCKS, get the lexion if you go with this block!
you have to get that clip way to tight over the cpu, if not, the cube slides down, i think i have mine tight enough, it hasnt moved with just the water going through it (no cpu running), though when it heats up, it might get slippier
overall
dont buy the kits.... if i had the chance to do this over again, i would go with the becooling aquacoil, the ehiem pumps, and a maze2 waterblack, plus that would have saved me 20$ (but shipping would probably ballance that out)
those are my words on their kit
-warflyr
overall
-warflyr
