- Jan 6, 2001
- Newville, PA
Just wondering if any of you are using this tank or pump, so far I haven't been able to find any stats on the pump other then it's 180gph. The only thing I'm worried about is that the waterblock(dangerdens) and the radiator(dangerden's cooloing cube) are copper and the tank is aluminum, if I used distilled water with a mixture of water wetter do I need to worry about it turning into a self contained battery? Thanks in advance.
