I've been trying to figure out what is wrong with my system for a couple weeks now. These are the different blue screen stop: errors ive received..
IRQL_NOT_LESS_OR_EQUAL <------ got this error a few times with different stop: codes
BAD_SYSTEM_CONFIG_INFO <-------- got this one once then I formatted
PAGE_FAULT_IN_NON_PAGED_AREA <----1st error after format
Process_has_locked_pages <-- 2nd after format
Along with a few screen freezes!!
Each of these errors I only received once except the first (but it always had different numbers after the stop: ) now my system won't even boot and I get a beep code (I WAS HOPING THIS WOULD HAPPEN ) I hope this will finally help me find out what is wrong..
I can't figure out which beep code it is though ..
Long(Beep) continuous DRAM isn't inserted correctly.
Short(Beep) continuous POWER supply has a problem
Does long continuous mean like one loooooong non stop beep or a long beep then a pause long beep pause ect.
Because im getting beeeeeeeeeep beeeeeeeeeep beeeeeeeeeep ect. LOL it's kind of hard to write but I think you get it...
.... I'd like to add I took the memory out and tried to start and got the same beep code but If it was the power supply then I believe it would error before even getting to the ram...
