Hello,
I've built a new rig with MSI GTX 1080Ti Gaming X inside.
I have an issue - there's pretty loud noise (not a coil whine) under heavy load which sounds like a bird chirping.
It came from PSU EVGA 750 BQ and I replaced it with ROSEWILL Gaming 80 750W, but the issue still there and now I think the noise comes not only from PSU but from GPU as well and they both perfectly synced and sound exactly the same (to test I moved PSU far from case).
Please take a look at these videos (old and new PSU):
It's not a mechanical sound and it's not coming from fans or case. Fans rotate silently and the sound starts under full GPU load only (I assume when energy consumption is high).
It's definitely coming from both PSU's I tried (attached videos), but in addition it's coming from GPU itself (though I'm not 100% sure about this). Also I tried different outlets.
I sent first video to EVGA tech support, and they said I may RMA. But second PSU is doing exactly the same sound, so I got stuck.
- - - Updated - - -
This is the second video, for some reason I can't add it to the thread:
- - - Updated - - -
