This is my first post but Ive found a lot of useful information here and Im hoping to find answers to the last few questions I cant seem to find answers to.
This is the system I'm planning on overclocking:
Case: Antec 600 Case
Motherboard: GA-MA785GM-US2H motherboard
Processor: AMD Athlon II X3 435 Rana 2.9GH
Ram: 4 GB Patriot Viper 2 DDR 800 CAS 444
Video Card: ASUS CuCore Series EAH4850 1gig 256-bit DDR3
CPU Cooler: Hyper 212+
PSU: 620 Antec Earthwatts P/S
I'm a little worried about the fact its not a full atx motherboard but I'm only trying to o/c the processor and nothing else. I don't know if this even matters but I thought maybe you guys would know more.
These are the settings I plan to have for my final overclock.
CPU Northbridge Freq. x9 =2115 Mhz
PCIe Clock(Mhz) 100
HT Link Width Auto
HT Link Frequency 1.6 Ghz Which is the same as x 8 or so Ive read. I will up this to 9 once stable
Memory Clock x3.33 = 783 Mhz
System Voltage Control
DDR2 Voltage Control Normal
NB Voltage Control Normal
SB Voltage Control Normal
CPU Voltage Control [+0.025V] 1.45 Volts
So this is how Im going to go about overclocking my system. Anyone see anything I need to change before I try this let me know. I was planning on setting the multiplier for NB, HT link, Vcore and Memory to what I hope the final overclock settings will be and I will slowly increase ref. clock by 10 until I hit 235. Is there any stability issues with having settings lower than spec? The fist reference clock test will be 210, so that would make my ram run at 699 Mhz, NB 1890 Mhz, and HT link at 1680. Or should I compensate the timings to keep them inline with spec? I know if its too high it will cause problems but is it the same if its too low?
PCIe Clock(Mhz) 100
HT Link Width Auto
