First of all I think Im going to to get an Aquastealth kit, because they are cheap, seem well made, and easy to use. The one that I like best is option 3 if you click here. But, I do have a few questions.
1. Other than cuting 2 holes, one in the bezel and one in the frame of my case is there any other case modification need?
2. Is there anything at all that I absolutly have to have or might be useful that is not included in the kit? Other than thermal paste and botls for attaching the fan to the case.
3. Should I attach the Fan behind the radiator or in front of it? what are the advantages of each?
4. Dumb question im sure. Does the radiator need power or does it cool by running water through a tube with fins to remove the heat?
5. Is there anybody using this water cooling kit, Original Aquastealt? If you are please tell me what you think. Ease of Installation? Leakage problems? Performance? Value?
6. What do I do about switching it on and off? If I am correct the only way to turn it off is to unplug it when I turn my computer off otherwise it will continue to pump water through my system, except that it wont be particurly cool since the fan won't be on. So should I just let it run constantly or is there a way to make it turn off without unpluging?
