Yuriman, here is a deal you can't refuse. I will give you a Gemini High Volume Block for
free. The only thing you will need to do is send it to Peter at
http://www.geminicool.com/ and have him put a new top on it for you. I dropped the block and broke the top. The top has to be sealed as well as screwed on. Now you can get a Dtek core and shroud.
This block served me well. For its size it does a really great job at cooling. I used a Eheim 1250 pump and it over powered the block. With the Via pump this block should do even a better job.
I will even throw in some Redline Water Wetter to mix with a gallon of distilled water.
The reason I say to buy 1/2" rad and pump is for the future. The W/B block has 3/8" fittings. You can soften the 3/8" tubing in boiling water and stretch it over the 1/2" barbs. Down the road you may want to purchase a 1/2" barb W/B. You can change out the 3/8" W/B fittings to 1/2" but you will not notice much difference. I had done this on my sytem.
This offer is for Yuriman and if he does not want the block, then the offer is pulled. It must be getting close to Christmas.
http://dtekcustoms.safeshopper.com/index.htm?994
D-Tek 1/2" rad/shroud $48.00
Gemini Block:
free
Delta Mid CFM 120mm fan: $13.50
Via-Aqua 20.5 watts/370GPH 1/2" pump: $23.00
$15.50 dollars left over for shipping, clearflex tubing 3/8", clamps, ASlll, T fitting.
Yuriman, this will give you an awesome first water-cooling system that you can build on. The only thing you may want to add down the road would be a second shroud and fan. Click on this link to an article I wrote that may be of use to you.
CLICK The article was written back when I was using the Gemini block...
Yuriman, please PM me if you want the block. I will be away until the evening on Sunday, but will get back with you.
FREEBIE
