- Jun 15, 2002
- Santa Barbara CA
I have upgraded my P4 several times and have a huge problem. I have been using a Volcano 7, which rocks the CPU forcibly if you install the clips one at a time. Now the SOB HSF has bent the pins on my new 2.5 so it won't seat in its ZIF socket.
I am going to RMA it, but I have a similar problem with a 2.26 caused by the same one pound chunk of swaying copper.
I've looked at other posts and folks say that the pins can be bent back. I am old and my eyesight sucks. I can tell the pins are bent by the occasional glint of stray light as I hold it up near a light bulb but I can't realistically mess with it.
Is there anyplace or anyone that fixes bent pins? I lost the Intel box so I can't provide the serial numbers or anything. I bought it used from a guy on Ebay. Should I try borrowing a microscope?
Any suggestions would be welcome.
I have switched to a gemini waterblock, which requires that the mobo be removed for installation, but puts far less pressure on the processor and keeps it about 15 degrees cooler.
