Best 80mm Case Fan to use with Maelstorm
Mr Fuzzie
Hey im looking to get 4 new 80mm case fans to go in my CoolerMaster ATC-201 case. I'm going to be using them with a Maelstorm (rheobus) so i can adjust all the speeds and everythign. Which 80mm fan do u guys recommend?
Also, i love the maelstorm, but it lacks lights...like the rheobus at pcmods.com has...but the maelstorm is already assembled...
is there anyplace that has the rheobus already assembled in silver?
Ferg
well if you have them hooked up to a rheobus then you can turn them down when you want to so why not get a high speed fan for when you need it. If money aint a thing then go all out and get Delta 80mm EHE. They are like 20 bucks a piece but judging from the fact you bought a coolermaster case and maelstrom you dont care. and you never know when 320 CFM of airflow would come in handy. Otherwise for 13 bucks a piece you can get Metronics 39 Dba, 53 CFM fans. The only place i know to get them is www.coolerguys.com though
