best air for 2.4c
sramjones
Disabled
Bronx New York
i am making a new pc and i am confucsed i am going make a new p4 2.4c system what is the best air cooling heatsink for this processor thermalright,thermaltake,zalman. I am planing to overclock the chip and much as possible so may someone plase help me.
sramjones
sramjones
Disabled
Bronx New York
it says thay it has to be used above 3.06 ghz p4 on the SP-94
Feature:
All copper design for maximum performance
Soldered fins to base to ensure effective contact
92mm stock fan for more cooling capability
Screws through motherboard mounting for LAN party
Technical Spec.:
Dimension:
L99 x W59 x H45 (mm) Top, without fan
L67 x W81 x H45 (mm) Bottom, without fan
Weight:
590g (heat sink only; for Intel)
Stock Fan
Maker: DELTA
Model: FFB0912EHE
Size: 92 x 92 x 38 (mm)
Bearing: Dual Ball Bearing System
Voltage: 12V
Speed: 4800 rpm
Air Flow: 110.18 CFM
Noise Level: 55 dBA
Intel: Pentium-4 socket-478 3.06 GHz and above
Toaster Oven
Washington, DC
You can use it on any Socket 478 MB that has room for it. Hell, you could use it on a 1.7Ghz Celeron if you wanted to (If you do, take pics :D )
