Best Bang for my 20+bucks
4everlurkn
delawhere
Looking to spend 20 bucks for heatsink&fan for an OC Duron system... Which ones are the best for my price range... TIA
Heatsink/fan
Welcome to the Forums!
For $17.50 an original Glaciator from Millenium-Thermal is a great buy. Good performer and quiet too!
DANG!!! i just paid 25 shipped for the goldengate!!! without a fan!!! dang! and now its 14 with a fan!!!
i HIGHLY suggest that heatsink!!! its great!! i have really bad airflow through my case and the hsf has a 18cfm fan and i get 47c, before i had my mobo and stuff outside my case and id get just barely 40c load on my 1700+ oced to 1900+
and thats with 18cfm!!! i have a really anoying fan that pushes a lot of flow that i have stuck on that thing.... but its terribly anoying! eaven with 7v
i dont remember the results with that one though...
and i had a 80mm fan adapted to it also and that had some GREAT results!!!! at 30cfm, but i recked the adapter trying to make it better.... i made the thing out of a cdr..
Anybody know where to find more detailed specs on the golden Gate base size? I cant exceed 60x60 base (maybe could go extra in length but not width)
Thanks...if those measurements are correct then it looks about 3mm too wide...capacitor clearance problem on an older mobo
