Hi all,
I've got this TuSL2C mobo, and a P3 1GHz. I am trying to overclock this PC to 160MHz FSB with moderate success. I 've had noname RAM up to 154FSB, Mushkin Rev.2 up to 153 (both 1*256), and now I have Mushkin Rev.3 (2*128). The problem is, I can't get over this 155FSB limit stable, and it's not caused by the CPU, as I have tested it with PC180 RAM, and this combination ran just fine @ 160FSB. I define "max stable FSB" as running SuperPi without errors, because those errors are most likely caused by a faulty RAM datatransfer. I stress the RAM quite a bit, by running it at 3.7V and the most agressive timings I can get. It can't be the temps, because @ 1.75V, it only gets 43°C with a Coolermaster/Delta combo.
The weirdest thing is, that WinXP shows me a BSOD at 157FSB and random resets at 155/156 (even whilst being errorless in SuperPi), but I am sure that the RAM can do 166 and up; the previous owner did this with a KT133A mobo... So right now, I am starting to suspect a less-than-opyimal BIOS. I have the "Evil inside" 1011 BIOS.
What versions do you use for optimal OC?
Gr, SuSEQ
Gr, SuSEQ
