BigStan said:situman
In your sig. You've got those 3700EB's at 5:4. Won't they run at 260? Or do you prefer to run them at 208 so you can run tighter timings?
OK - I forgot about that 2.8v limit of that mobo - sorry. Can't find your thread. If you run across a link I'd like to look at it.situman said:only 2.8vdimm so no chance of really running 260 fsb. going to do a vmod on my ic7 then i will definitely crank it up. besides i scored 5700mb on sandra with 208fsb so im in no real rush to crank it any higher. I have a thread "just received my EB "or something like that u can check out the screeny i made
BigStan said:BIOS 16 got a bad rap because a couple of guys vapo chill at 4.2ghz lost a couple of points when they updated from 15 to 16. Also hand full of ppl had problems flashing their BIOS. I lost a few points on my mem OC on 16 so I went back to 15. On BIOS 15 my CorsairXL could do 258 1:1 2.5,3,3,7. On BIOS 16 the most I could get it to was 255 2.5,3,3,7
Sometimes in their hurry to fix something, they break something else. Just the way computer programming goes. Sometimes the best BIOS are the ones where there are not a lot of fixes. They just "oprimize the code' of a BIOS. That was what happened in 15. Then they will try to add something new in 16. It might take a revieion or two for them to get around to "optimizing" again.lilneel12 said:does anyone know why the bios makes the ocing flucuate??
-if anything the bios revisions should stablize the problems. i give up, im just leaving it at 240fbs for now
You already have 4000 mem. If you are running at 240, it is running under spec. Getting 4200~4400 will just make you mem even more out of spec. What is your back up plan if buying 4200 mem doesn't get you past 240?veryhumid said:yay bigstan memory guru! So it looks like you lost maybe 3 points, and we can both go up to about 3 under rated speed max. I am going to try some 4200 or 4400 as soon as I get paid and if i can go past 250 we will know it was our board, not memory. I will make a big post if it works out.
