- Sep 8, 2002
- Vancouver Canada
filip04 said:WHY don't you try this???
http://www.xingtech.com/
audio catalyst... you can rip to wav, or mp3...
i, too, have had probs with cdex, but never with audio catalyst... just make sure you have aspi installed... (wnaspi32.dll in your system32 folder)
ps
maxvla, nice avatar (HOTTIE!!!!)
Gnerma said:
ASPI is probably the problem with Exact Audio Copy (Maxvla) and Cdex (jacheatamobits).
Audioaficionado said:I downloaded EAC and LAME as separate apps. I dropped LAME first then RAZOR/LAME in the same folder for wav to mp3 conversions.
Secondly, I dropped EAC in its folder and pointed it at LAME for mp3 encoding durring setup.
Nothing to install as they both work without all the registry key complications many other apps insist on.
Originally posted by cornbread I like to use EAC to rip and RazorLame to encode. By the way guys, if using lame make sure you stay away from the newer version (3.93 and up) for they have some bugs. 3.90.2 and 3.92 are the versions to use, 3.90.2 is probably the better one due to the fact that it has been tested more than the later versions.
What bugs are in LAME 3.93?
I've got 3.92 and it sounds great on my system.
Heat said:
filip04 said:you can change quality with lame??? :O
