I'm looking for the best cheap AMD motherboard. I don't really want to hit into the $100 range..so i'm ruling out the NF7-S. $80's is ok..but $40-50's is preferred. Basically, the cheaper the better. But I want something stable, can run at decent fsb speeds, has AGP 8X, and integrated sound. Might sound like a lot to ask for, for the price..but i know its do-able. Even micro-ATX is ok.
Any suggestions.
Btw..this is because my A7N8X seems to be screwed up. When it does the memory check..its really really slow (I can read each number as it goes up..good thing it doesn't increment by 1's). Even the biios seems to run slower then usual...and so does harddrive detection and everything else after it. Its boots but not stable. Does this sound like a mobo problem...I've practically changed all hardware before, besides the mobo for testing..so that seems to be the problem. =T
Thanks for any help.
Any suggestions.
