best choice
murdoch
i am leaning toward the asus p3v4 slot one over the asus cuv3/4x cause the slot adapter gives an advantage to over clocking because their may be a problem with voltage since the both boards could potentially have a problem over clocking with added voltage returning to auto detect when you reboot.how ever a friend is using a abit vp6, which uses the same chipset(although dual). Does abit make a board like this not dual. I was told that the vp6 came with the agp memory tweak on it. As well i want 4x and a good agp divider which board should i be looking at for oc my cel2 633 then, with the most sucess and perks.My main reason to stick with the newer via chipset is its much cheaper than the intel
theyre all pretty good choices. Abit does make a single slot version of that board i believe
