Best controller for Flight Simulator?
BigBadBaz
NY, USA
Hi. I just bought Lock On: Modern Air Combat and I need a controller for it. I don't really know anything about joysticks/yokes, what to look for, what's considered goo, and I don't really even know much about flight simulators.
So my question is, what should I get? I don't care if it's a joystick or yoke, whatever's better. Although if I had to choose I'd probably say joystick with throttle. I don't even know enough to set a budget, so whatever you guys recommend and I'll decide from there.
One joystick which I thought is cool and seems to have a lot of nice functions is the Saitek X52 USB Flight Control Joystick, but I don't really know enough to know if it's any good.
Any suggestions would be greatly appreciated.
Thanks in advance!
I just use a regular ol microsoft joystic from 5 years ago. Works great with flight simulator x, but I'd get an updated one if I was shopping for one...I'm thinking something with throttle and a couple thumb buttons..
-D
Those Logitechs are cetainly cheaper, but I think I want something with a throttle.
Anyone have experience with the X52 or heard anything about it?
Both the X-52 and X-52 pro are good sticks. I use the X-52 and find it to be a very good stick for the Price. I've had my X-52 for almost two years and it is heavily used and Ive had no problems with it.
The major complaint I've heard about the X-52 is the spring tension being soft, it is softer than most sticks, but I don't find it to be a problem.
The ability to program the buttons for different profiles for different games is nice. I play IL-2, FSX, and FlightGear. The X-52 works well in all and I never have to touch the keyboard.
I went with the X-52 over the pro because it didn't seem to offer that much more for the extra cost.
Thanks for the reply.
I actually ordered the X52 Pro last night. One of the reasons I went for the pro is because they supposedly fixed the tension problem. Also because I like the looks better. ;)
Thanks for all the help!! :beer:
Thanks, that thing looks seriously messed up.
I actually already got the X52 Pro. It's a pretty cool controller but I am still working on setting up the controls for HOTAS. Unfortunately I can't find any X52 Pro profiles for LOMAC, so I'm trying to set it up for myself. Not so easy for a complete newbie. :bang head:
I also can't believe how many controls there are to fly in a simulator!! I guess it's closer to reality now.
Yep, the joystick and throttle each weigh about 8 pounds, I like the all metal construction. even the buttons are metal.
Try some of the flight sim forums. You can try cougar world (although it's for the cougar) I recall seeing posts for the siatek x52 posted there. Also check the official saitek forum.
