- Mar 18, 2002
- Sunnyvale CA
Best cooler for slotket-based cpu?
Hardware:
- Abit BF-6
- 1GHz P3 100FSB FC-PGA cD0 w/ MSI 6905 slotket v2.3
Goal:
- Adequate cooling for 1330MHz (133FSB)
Constraints:
- ~55mm between cpu core and first dimm slot
- Must maintain access to all dimm slots
- Must maintain eardrums (<40dB fan)
Would an SK-6 w/ a 60x60x25mm fan block any dimm slots?
Does the S370 lever on MSI's slotket interfere with the SK-6?
How about Abit's green BX heatsink, is there enough vertical clearance for the SK-6?
If this cooler won't fit, are there any others as good or better that will?
TIA,
Gnome
Hardware:
- Abit BF-6
Goal:
Constraints:
TIA,
Gnome
