I want to drop my cpu temp. 5-7 degrees celcius. right now I'm running 2 case fans and the FHS that came with the [email protected] 980mhz. Can anyone tell me what good FHS I can use to drop temp. I will be also using some thermal grease maybe arctic silver 2or the one radio shack sells . Has anybody had any luck with that one? I also want low fan noise levels .
Any ideas?
Thanks
ps. my load cpu temp is 45-47 degrees.
Any ideas?
Thanks
