best drivers for ti4200
I did a little comparison with my ti4200 a while back and found that the newer the driver (basically), the lower the 3dmark 2001 score and higher 3dmark 2k3 score.
I personally use 43.45, but they all work pretty much the same.
I am using the 30.82 atm, but used the 43.45 for ages, had no problems with them - I see no difference between them but the setup interface so just go with whichever :)
