- Aug 2, 2012
So my main system has 3 drives:
128GB Sandisk Ultra Plus SSD
160GB Western Digital Velociraptor
640GB Western Digital Caviar Black
I have dual-booted Win 7 Pro with Linux Mint for a while. However, I would like it set up so that all of the OS files / registry / maybe a couple programs are on the SSD for both OSes.
I was planning on ~35GB partition for Linux Mint, and then the remainder (~80GB+) for Windows 7. However, this is my first time "reformatting" an SSD. Is there anything in particular I should know? I know for the dual boot to function properly I will need to install Windows first. But for the format / partition should I use the one built in to the Windows installer? User Partition Magic?
I just want to make sure my SSD gets reallocated for maximum performance, minimizing the potential negative effects of formatting or partitioning incorrectly, as I'm not sure what the current consensus is for modern SSDs.
I'm sort of considering splitting all 3 drives, like this:
128GB SSD: ~35GB Linux, 80GB Windows
160GB 10k HDD: ~50GB Linux, 100GB Windows
640GB 7.2k HDD: ~120GB Linux, 500GB Windows
And I want to do this is the way which will give the best boot times and general performance.
Thanks,
Tyerker
Thanks,
Tyerker
