- Jun 16, 2001
i want to download Linux...which is the best im talking easy to setup up and is most compatible with the setup in sig
funnyperson1 said:i found a copy of Corel Linux for Download..is this good and will it work with my system, and about the buying part...im too cheap...id much rather struggle and install it myself...
mcrites said:You probably don't want to use Corel. I do not know if they have updated their distro in the past year, since they dropped it due to funding problems and lack of popularity. Most people seem to like Mandrake or Redhat, I would go with one of those, then graduate to debian.
funnyperson1 said:update: i installed it and everything and my floppy dirve doesnt work and all i could see was:
1010101010101001 101010100101
1101...you get the idea? i had to reformat and reinstall Windows XP.....ill wait till i get a new hdd and put it as secondary master (the one i installed on this time was slave) and then install Linux....pretty easy setup though and lots of free stuff. ...me like![]()
I would strongly recommend Mandrake distro, since it has the easiest setup and is user-friendly ( not like RedHat which almost suck me friend into the screenfunnyperson1 said:i want to download Linux...which is the best im talking easy to setup up and is most compatible with the setup in sig
portorock said:fro some reason, I can' get back to the linuxiso page to see if they had any directions. I tried on my laptop also, but no luck
