best LCD screen within reason
DayUSeX
well im looking for something that is 21+ inches, and i would like for it to support 1600x1200 or higher. So what is the best, preferable with no ghosting and best image quality. thnx
You probably would want a LCD monitor that uses one of LG Philips' new 16ms panels.
23" LM230W02 Flat Panel
20.1" LM201U04 Flat Panel
The Dell 2001FP is the only monitor that I know of that uses LG Philips' new panels. The 23" Apple Cinema display uses LG Philips' panels, but I don't know when (or if they already have) switched over to LG Philips' new design.
The Dell 2001FP sells for about $899. The 23" Apple Cinema display goes for $1999,
Anandtech's take on the 2001FP - http://www.anandtech.com/showdoc.html?i=1918
thnx im going to look into the dell 2001fp, but dang that is a ton of money 899 usd, but oh well hopefully reviews show it will be worht it
lololololol, you want to buy a gaming LCD over 21" inches and with a resolution over 1600x1200 but 899 is a "ton?" You're in the wrong boat, junior.
Also, Dell has a wicked sale on their 2001FP's right now for 750 bucks with free shipping. I'm getting one myself, which says a lot.
well seeing as my sony 21" just fine yeah it is a"ton" seeing as im not really getting much of an upgrade ok!
